command hq
First post, by katralic
Does anyone know a way to play command hq in full scree? I use dosbox and it plays ok but only in a window. Even if I cant go full screen can I make the window bigger?
Reply 1 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Search DOSBOX forums... Even if fullscreen does not work for you there are ways to get arount it... (basically setting the size of the window to cover the whole screen).
And ask DOSBOX questions in DOSBOX forums, not here!
Mirek
Reply 2 of 4, by HunterZ
* Moved to DOSBox General forum *
Alt+Enter will switch to fullscreen, and there are options in dosbox.conf that let you set it up to start in fullscreen by default. If this is too intimidating, try using D-Fend to help you set it up.
Reply 3 of 4, by mirekluza
DOSBox Moderator
I hope he knows that 😀 . My guess is that for whatever reason the fullscreen does not work for him (crappy notebook etc.).
Mirek
Reply 4 of 4, by Guest
I didnt know about alt enter. Thanks for the info it worked great.
