First post, by decypher
RetroGames AIO is a usb stick launcher for retro games or other programs.
Thus, it uses relative paths. Everything beneath the program folder will be treated as a relative path. Due to this, you can copy and move your whole collection, without loosing the path data.
When clicking on a game, the corresponding box cover image is being downloaded from the internet. It takes the first hit it finds, so it may be missleading, especially with games that do have different episodes.
Double clicking a game after selecting the category will launch it.
RetroGames comes with an integrated directory scanner which helps you adding games that have been copied to the application's root path. The game name will be taken from the directory name of the game's exe.
For example, if your game resides in "e:\games\adventures\Larry Laffer\larry.exe", and your application exe is in "e:\games\RetroLauncher.exe", the saved path will be "adventures\Larry Laffer\larry.exe" and the game name will be automatically set to "Larry Laffer".
