Mount CD in Linux
First post, by caltrop
The example in the documentation does NOT work!
Linux Mint - Ubuntu based
/media/cdrom
does not exist
/dev/cdrom
does not work
/media/user
accesses the mount point, then 'cd <cd name>'
but this confuses programs expecting stuff in the root directory of the CD
/media/user/<cd-name>
CD's are mounted in Ubuntu/Mint by CD name, not device
so everytime a CD is used it has to be mounted by name, NOT device
if CD name has spaces it has to be quoted
Because each CD has to be mounted individually by name this makes DOSBox a bit cumbersome.
Some of those CD names can be quite long: 1998-06-27-GamesRUs-whatever
requiring: mount d /media/user/1998-06-27-GamesRUs-whatever -t cdrom
then restart DOSBox or mount -u d
Reply 2 of 4, by catchaserguns
Go find the game on Amazon and buy it then come back to the forum.
Reply 3 of 4, by gdjacobs
Why mount the drive first first? Dosbox handles the raw images just fine be they iso files or bin/cue images. Image the disk and load it using IMGMOUNT.
Of course, if you're getting dodgy game images from sketchy websites, all bets are off.
Reply 4 of 4, by caltrop
FIXED CD MOUNT ISSUE!
use gnome-disks or whatever you use
turn OFF disk auto-mount
you select the disk label here as well
now the CD is fixed & not variable
the DOSBox configuration command in [autoexec] now works for ALL CD's
mount d /mnt/[disk label] -t cdrom
instead of a CD showing as /media/[user]/[disk name] for every CD inerted
now it is /mnt/[disk label] for every CD
I also did this for Win10 directory since it was not mounting at startup
only mounted when first accessed
not that I use Win10 much 🤣
Hope this helps.
As usual forums are little help, you end up figuring it out yourself.
And people need to be a bit nicer & not so condescending.
Newbies are TERRIFIED of Linux and being mean doesn't help.
We're fighting for a Free Operating System.
I'll be a Linux Expert soon... 😊
