First post, by Avenger
I've been using DOSBOX for a few years now and for the sake of consistency would prefer if I was able to open folders and run executables with spaces in the name.
Is this possible?
I've yet to find a command that works.
Cheers.
Reply 2 of 8, by Avenger
Dominus wrote:
You can mount folders with spaces but then you are limited to Dos conform folders and file names
Alright,
Let's say I want to play a game and the executatble is located in:
C:\Program Files\DOSBox\Games\Terminator\Future Shock\Future Shock.exe
What would the command be to run this without having to eliminate the spaces in the name of the last folder and the executable file?
Reply 3 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
You cannot. Keep the games as they were and don't add spaces to folders and exe. Dos naming scheme of 8+3 (filename+extension)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 4 of 8, by Zup
You can't. DOS rules (back in the day) were 8.3 names without special characters (i.e.: dots, spaces).
You can do something like:
mount f "c:\program files\dosbox\games\terminator\future shock\"
So your game directory will be mapped to f drive, but then you would have problems to run that "Future Shock.exe".
I'm selling some stuff!
Reply 5 of 8, by Cyberdyne
Volkov Commander can open directories with spaces. I dont know if Norton also does.
Reply 6 of 8, by Dominus
DOSBox Moderator
It might not work IN DOSBox as DOSBox won't show the directory with spaces correctly so the directory it want to open might not exist...
Reply 7 of 8, by Avenger
The quotation marks did the trick.
DOSBox doesn't like executables with spaces though...
I even tried 6 characters and a ~1 suffix without any luck.
Thanks for the lesson.
Reply 8 of 8, by Dominus
DOSBox Moderator
Yes, because the file name is "future shock.exe" not "future s.exe" or "future~1.exe", so when you enter those the exe is not found.
