First post, by IcingD
I desperately need help in getting Dosbox to work. I tried to search help to my problem from previous posts but didn't find any, so excuse me if this has already been gone trough couple of thousands of times...
So, I have used Dosbox before, that is not the problem. I just removed it from my computer (don't remember why) about half a year ago (or atleast something like that), and now when I'm trying to use it again the thing won't even start up. It just quickly flashes something along the lines of "Exit to error: can't init SDL DirectInputDevice" and then lots of numbers and gibberinsh with a couple of mentions of unknown DirectInput error.
And if this is really simple thing that everybody should be able to solve then my apologies in advance, I am not much of a computer mechanic or guru, I just know the basics of how to run them.
I have the latest version of Dosbox, 0.65 that is, and my computer is AMD Athlon 2500+ 1.84 GHz with Windows XP, and I have Radeon 9600 VC. I have already tried using older versions of Dosbox, but encountered the same problem with them also... I am really clueless of what I should do. Any ideas?
Thanks in advance!
