First post, by aurelionet
Hello Everyone,
I'm new in DosBox and I'm using to Run an old Clipper software (8 bits) in 64 bit, and all working fine, except to display special chars in screen like ã for example.
In old DOS systems I used something like DEVICEHIGH=C:\WINDOWS\COMMAND\DISPLAY.SYS CON=(EGA,,1) in config.sys
How can I do this in Dosbox?
Attached one image of "problem". Take a look in some chars.
Reply 2 of 13, by gdjacobs
Using something like vDosPlus might work better for you.
Reply 3 of 13, by root42
Or simply run a VirtualBox with MS DOS as guest. Should be fine for Clipper.
YouTube and Bonus
Reply 4 of 13, by kruwi
I would rather install MsDos (or Free. Dos) in dosbox, using a virtual hard disk image. It's much (!) better for MS Dos than VirtualBox and the like.
Visit the end of the internet: www.groskreutz.de
Reply 5 of 13, by root42
But Dosbox isn’t a full virtualization...? Or is it? I thought it’s DOS and BIOS routines were builtin?
YouTube and Bonus
Reply 6 of 13, by kruwi
In my opinion, dosbox + installed MS Dos will give you the most perfect emulation that you can get.
Reply 8 of 13, by gdjacobs
kruwi wrote on 2020-01-07, 21:32:
It might work well for you, but there are certain things that have been excluded deliberately from DOSBox because they're not really important for DOS gaming.
Reply 9 of 13, by kruwi
Printing comes to mind, of course. But if you have installed MS-DOS inside Dosbox (as I have recently done) at least share.exe and the like will work. Any remaining loose ends would probably be caused by an incomplete BIOS emulation.
Reply 10 of 13, by kruwi
The next step would be to use PCEM. Slow, but ok for dos stuff. Even my quite crappy laptop manages to emulate a 486DX using PCEM 1.5.
Reply 11 of 13, by aurelionet
gdjacobs wrote on 2020-01-07, 16:31:
You know how can I print from VDOSPLUS without DOSPRINTER?
In Daum version of DosBox I can!
Reply 12 of 13, by gdjacobs
aurelionet wrote on 2020-01-08, 19:25:
Daum isn't supported here (or anywhere that I'm aware of). You can use other filters with vDosPlus. Consult the documentation. If you have further questions regarding vDosPlus, they have their own forum. Please follow standard netiquette and do a quick scan or keyword search through the archive to see if your question has already been addressed before opening up a new thread.
https://sourceforge.net/p/vdosplus/discussion/general/
Reply 13 of 13, by Jo22
kruwi wrote on 2020-01-08, 17:27:
There's also MS-DOS Player..
Here's a review from 2011: https://virtuallyfun.com/wordpress/2011/02/11 … s-dos-player-2/
Emulation surely has quite improved since.
