First post, by Gene Wirchenko
With the type command, if a file has a <Ctrl-Z>, DOSBox will display that as well (as a left arrow) on my system. This was also the case with 0.63.
Sincerely,
Gene Wirchenko
Reply 1 of 3, by eL_PuSHeR
I am pretty sure ms-dos itself did the same thing with some files.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 3, by wd
Rank DOSBox Author
DOSBox Author
No, but the dosbox type isn't intended to be msdos type identical.
It's used to check file contents, even beyond eof markers (^Z)
thus it'll display special characters as chars and not interpret them
(at least some).
Reply 3 of 3, by Gene Wirchenko
Not that I ever saw. I have been using the batch file with the type command for years. What it does is display a file that contains the ANSI codes for displaying the command prompt at the bottom of the screen. It has never displayed the EOF on any MS-DOS system or window that I have used it on.
Sincerely,
Gene Wirchenko
