HunterZ wrote:AdPlug is supposed to be able to play DRO recordings in Winamp, althought I've never been able to make it work myself: http://adplug.sourceforge.net/
Note that OPLx chips are not MIDI synthesizers and that raw OPL is completely different from MIDI, so there is no way to do any kind of meaningful conversion between the two formats.
bouth midi and OPL share the same technoligy by using notes
But for sure, you cant do all the stuff in midi as in OPL
but all kinda adlib and midi are sequenced music.
So in fact, if you have a converter that can read a spesefic format, you can dump all the notes from a adlib track to a midi.
It only question about the correct tool.
But for sure.. it woulnd sounds like the adlib track, beacuse the midi bank has there own sounds, 128 instruments + percussion.
The adlib tracks, you can somehow say, the possibilities is "unlimited"
i have sucsessfully converted the wolfenstein intro track to an another module/sequenced track that is compatible whit newer platform, such as FMOD.
There are a few tools you can do some nasty tricks , to make it possibilities to make midi`s or even betther, make your own remixes.
The ultimate tool isnt avatible yet
when a RAW2MID is out, you can say, "sure ! adlib track to midi is possible"
since Winamp can export almost all kinda adlib format to AdLib RAW
