DosBox performance i7 920 vs AMD 4000+
Reply 20 of 22, by EmperorsDynasty
The 920s are so easy to overclock, it's unbelievable... and enjoyable! I'm running at 3.85ghz with a fancy (but not the absolute best) heatsink and am under 80c at loads... of course... DOSBOX with intense games like Battlesplire won't even bring it above 14% usage!
4+ghz is obtainable too, but I don't like warmer temps above 70s.
I think that out-of-box, depending on how could of a chip you got you could PROBABLY get at least 3.2ghz with stock cooling.
...but yeah... DOSBOX runs great on this CPU.
Reply 21 of 22, by temptingthelure
Kudos for the 920s for making the old games playable again! 😁
btw, anyone think redguard or battlespire will be the next freeware release game of the elder scrolls?
Rise of the Triad modding site!
http://rott.s4.bizhat.com
Reply 22 of 22, by DosFreak
Battlespire more likely than RedGuard unless DOSBox officially supports glide by then. (Unless you'd want the software ver of RedGuard YUK!)
Make your games work offline
