Idea for Adlib Gold emulation?
Reply 20 of 26, by The_Atomik_Punk!
Hey ripsaw8080, I'm having trouble getting your modified driver to work in Dosbox with the CD version of Dune.
I copy and pasted over the default DUNEAGD.HSQ file with your modified one in my DuneCD folder, but when I force Adlib Gold in the INSTALL.EXE, the game refuses to boot; it just hangs at a black screen when run. Is your driver not compatible with Dune CD, or am I just doing something boneheaded?
Reply 21 of 26, by ripsaw8080
Rank DOSBox Author
DOSBox Author
The modified driver only works with the floppy version of Dune. The CD version reads all of its files out of the big DUNE.DAT file on the cdrom, which includes the drivers, and there is no easy way to make the game use modified files.
Reply 22 of 26, by The_Atomik_Punk!
Ah, that makes sense. I suppose there wouldn't be much appetite to add Adlib Gold support to Dosbox, seeing as it was only utilized by a couple of games from what I understand. Perhaps I'll give the floppy version of Dune a whirl to try out your modified driver; thank you very much for your efforts.
Reply 23 of 26, by dricks
Download the latest DosBox SVN
http://www.emucr.com/2016/02/dosbox-svn-r3964.html
Then set your OPL Mode for your Dune game to "opl3gold" value.
You'll probably have to edit your frontend or your CONF file to set this specific oplmode.
In DFend Advanced (which i use) you can add additionnal config parameters yourself.
Launch the setup of Dune and select Adlib Gold (it will works flawlessly)
Then open your ears and enjoy AdLib Gold emulation ;D
Reply 24 of 26, by farvardin
very cool !
I hope a new release of dosbox will rise some day!
🎵 🏰 🎹 My chiptune and Dungeon Synth musics: 🐺 Website - Bandcamp - Spotify
Reply 25 of 26, by SEGStriker
PCem emulator already emulates Adlib Gold, without daughter board though.
Reply 26 of 26, by lightmaster
Yes, yes and this is almost a necropost.
