Again, reading comprehension. He has already done it, even if it is incomplete. The two demos he has up are running through jDOSBox with what he has already done with the APIs. He specifically states that he cannot use Windows online.
Win95/98 and their setups should run find in jDosbox, but unfortunately you can't run those online because they aren't free
There would have been no point in danoon publishing a demo of Windows installed in jDOSBox. He also states that not everything works like:
The menu, caption and other non-client areas of the window are missing, but other than that it seems to work pretty well.
If he had simply loaded Windows 9x in it, these things would work.
I am sorry if I have been a bit harsh, but after hijacking a thread then stating that you said:
If only someone would pair Wine with dosbox's CPU core and port it to Windows
I provided a link to the closest thing to this that actually works, you responded with snark. It tends to rub people the wrong way. Great way to start out on a new forum.
