Reply 40 of 49, by Guest
wrote:GUS Pnp does that list but has a cleaner DAC, 8192 panning steps, 16bit samples vs emu8k which clips everything to 13bit, 32 channels where emu8k is limited to 30.
GUS PnP can NOT 'do that list' because in EMU8k almost everything is patented. It would be cheaper for Gravis to buy EMU8k chip than paying for every patent it has. AMD Interwave chip can do only lineral interpolation (as other high quality synths) - EMU8k has patented multipoint interpolation - that's why sounds cleaner than the rest when low quality samples are used (almost all old DOS games, Amiga mods).
The only company which broke Creative monopoly on EMU multipoint interpolation was Aureal with Vortex2 chip (27 point interpolation). This was the reason for Creative to sue r.i.p Aureal.
In GUS PnP you can put max 8 MB RAM in AWE32 up to 28 MB.
GUS PnP uses AMD Interwave chip which is completly different from EMU8k.
Some revisions of Interwave chips used to hiss (Gravis reaplced these cards in some, more client rights protected, parts of the World)
EMU8k has digital SPDIF output ( 2 pin connector available on all AWE cards) so clean DAC does not matter.
EMU8k has 32 channels. The 30 channels you mentioned are because Creative to cut down costs of another DAC wired OPL3 FM stereo to EMU8k stealing EMU 2 voices. In pure DOS without Creative driver (when EMU8k mixer is not yet programmed to process OPL3 stereo output) you have all 32ch for use. However this greedy Creative behaviour has advatange: with EMU8K you can apply reverb, chorus (or other effect) on OPL3 sound making cooler sound than in original (or on other cards) 😀
On EMU8k you can upload your own sound processing algorithms - some of AWE32 drivers offered Qsound stereo - which was such algorithm uploaded on EMU8k during driver init. Creative never released EMU8K DSP assembler so users could never write their own effects. However some limited effects creators appeared made by skilled programmers. Better situation is with EMU10k1 - we have such assembler which comes with linux driver tools and Prologic Surround Decoder algorithm which you can upload on EMU10k1 if you wish.
