Aspect ratio in fullscreen (widescreen)
Reply 42 of 51, by mnn
It is hard to reproduce, because even I have problems to reproduce it 😀 Sometimes manually mounting as non-C drive works sometimes don't (C works always). Now, I was able to freeze DOSBox running BAT file (unmodified, which worked before) 😀 DOSBox is real mystery to me now.
EDIT: DOSBox freezes always now running BAT file, I don't know why, I restarted PC, so far nothing works.
Reply 43 of 51, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
please give us the contents of the batch file (or is it any batch file?)!
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 45 of 51, by Dominus
DOSBox Moderator
this sounds very strange and not normal Dosbox behaviour. Does a simple batch file with just the content
intro
freeze as well?
If not please give us any example of a freezing batch file.
If it does freeze, then there is something seriously wrong on your end.
Reply 46 of 51, by MiniMax
Rank Moderator
Moderator
Who made those BAT-files, why, and how?
_________________
Reply 48 of 51, by Dominus
DOSBox Moderator
You are really resistant to help, aren't you? All questions aimed to help you get ignored, at least the important stuff (like the contents of the batch files, or running mem before and after...). Something to remember next time...
Reply 49 of 51, by mnn
1) I didn't ignored anything. Don't assume anything.
2) Contents of batch files are irrelevant, they recusively called themselves (by mistake).
3) I did run mem before and after, you've been sleeping through that part of this thread.
4) Just remember... I''ll remember not to listen to guy like you.
Reply 50 of 51, by Dominus
DOSBox Moderator
-> I just went by what I read
-> Since they called recursively themselves the contents WERE relevant
-> you never reported back on this except for
Well it is totally independent which drive I use to mount the folder as long as I do it manually. Using Autoexec section or some BAT automation crashes the whole thing up. I think this could (finally) be DOSBox issue.
and
It is hard to reproduce, because even I have problems to reproduce it Happy Sometimes manually mounting as non-C drive works sometimes don't (C works always).
This isn't much of a report, is it?
-> your loss, since guys like me are the ones that actually try to help guys like you...
