First post, by EdusP
Hello , fellows , i tried to mount a real floppy disk by mount a a:\ -t floppy , and when i try to access the floppy it gives me that Dos error , General error...
It is formmated , and have some Msdos programs.
thanks
Reply 1 of 2, by eL_PuSHeR
Rank Moderator
Moderator
Are you sure the floppy is still readable?
Maybe the program(s) are using some sort of low-level disk-access not supported by DOSBox.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 2, by EdusP
I am sure it is an authentic MsDos floppy. But the diference is that i am using DosBox with a 126 Mb bootable MsDos 6.20 Hard Drive image and not only a directory mounted as a drive C. May be the MsDos under the emulator cannot see that Floppy properly. But it mounts fine without MsDos.
It just a little detail i realize using DosBox with MsDos v6.20.
Thanks.
EdusP
