First post, by XenOtai
Sorry for asking you for help, guys, but i have a real trouble!!
I haven't changed any settings in the config. file but sound is still missing in EVERY game. My PC is good enough.
So couldn't you tell me what's the trouble, please??
Reply 2 of 7, by eL_PuSHeR
Rank Moderator
Moderator
Yeah. DOSBox emulates a Sound Blaster 16 by default.
Port: 220h
Interrupt: 7
DMA: 1
HDMA: 5
And much more! Just edit your dosbox.conf file to see available options.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 3 of 7, by XenOtai
Well, thanks, the sound is now working.
But now it stutters!! I have tried to increase the prebuffer, and even set it to 1000, but it didn't help!!
I quess i have to mess up with the cycles, but there is one thing: i don't know what is the optimal number of cycles, beneath which the game will run slow, so i'm afraid to low the number.
And, please, could you tell me what for do you actually need to RAISE the number of cycles?
Reply 5 of 7, by `Moe`
Changes in the config file only take effect after you restart dosbox. To change cycles while running, use Ctrl-F11/F12. Lower cycles until the stuttering disappears, then you are using the best value. One common trick to improve performance is setting "core=dynamic" in the config file. It may crash with some games, however.
