Sound Skips
First post, by Chubster98
Everything runs great and real smooth on DOSBox except one thing. The sound, it catches real bad and its annoying. Ever since i started using D-Fend, the sounds been acting up. I didnt know how to configure the sound to where its best. Anyone know how to help me?
Reply 1 of 6, by red_avatar
It's simple: skipping sound means your computer can't handle the speed DOSBOX is set at. Usually sound suffers first - I found that higher cycles may make a game run more fluent even if sound chops up, but it's not worth it. Just lower the cycles. Or, of course, use Dynamic mode, which can handle more cycles without the sound chopping up.
Reply 3 of 6, by eL_PuSHeR
Rank Moderator
Moderator
Edit dosbox.conf using notepad and change the line core=normal with core=dynamic
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 6, by avatar_58
Well d-fend has its own default options, so you might want to check to make sure anything you have edited before in your dosbox.conf is set in the game's profile. D-fend does not even consider dosbox.conf so make sure all your settings are correct in the profile.
Reply 6 of 6, by Karbous
Well, I have the same problem (with game I have no mouth and I must scream), and I think I solved it. I set CPU core to dynamic, but when I set higher cycles (20000), the sound is bad, but the speed of game is good. But when I set to 10000 cycles, the geme speed sufers sometimes (in animations), but the sound is absolutely smooth. Well, it seems like more cycles are not always better.
