First post, by SuperCOP
I'm writing to all forum because there's a little problem.
DOSbox runs great, but there are some programs or games (Like Duke Nukem 3D) that search the midi setting and obviously, there are no address to find the midi settings.
The line in AUTOEXEC.BAT is:
SET BLASTER= A220 I7 D1 H5 T6
but... where is the midi address?
A DOS program, the Fast tracker 2, on the settings has the port 330 as default midi address. How it's possible to add the midi settings on DOSbox starting to have all programs/games that run perfectly?
Thank you!
Reply 1 of 1, by DosFreak
You can solve this easily enough....add the following line to the autoexec portion of your dosbox.conf:
SET BLASTER= A220 I7 D1 H5 T6 P330
AFAIK, no program actually requires that P330 be set unless it's dumb and checks the SET variable for that line. Duke Nukem 3D works fine without it.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
