First post, by japheth
Hello,
how can I make DosBox support the "<"/">" key (german keyboard). I created the binary from current cvs and can see in the source that there is some support for this key (KBD_extra_lt_gt, code 0x56) implemented, but I don't know how to activate this support.
Regards
Japheth
Reply 2 of 22, by japheth
> What OS are you using?
the binary runs on win98se
> What do you need this key for?
seems a strange question to me. for example for output redirection. currently I have to press alt+np6 and alt-np2 to get the ">" key
> For linux/windows maybe try usescancodes=true in dosbox.conf
I tried adding this entry to the [sdl] and [dosbox] section, but it didn't change the behaviour.
Reply 3 of 22, by Qbix
Rank DOSBox Author
DOSBox Author
wd forgot to mention that you would need
http://cvscompile.aep-emu.de/dosbox.htm
and then please try again. (and if it fails again add that usescancodes=true)
Water flows down the stream
Reply 4 of 22, by wd
Rank DOSBox Author
DOSBox Author
I assume he builds it himself already. But you might want to compare
it against some prebuilt version.
This key isn't used normally, as the default dosbox keyboard layout is US.
That's why i asked if you really need this KEY or just the > and <
(which you should find between the keys "M" and the right shift,
that is SHIFT+, and SHIFT+. with a german layout, unless something's really wrong).
Reply 5 of 22, by japheth
downloading the binary from cvscompile.aep-emu didn't change anything.
> really wrong).
I forgot to mention that I'm loading a (mini) german keyboard driver in dosbox (which intercepts Int 15h, ah=0x4Fh). So between 'M' and the right shift key there is no more "<" and ">".
"<" and ">" on german keyboards are on the "102-key", and pressing this key currently produces no make or break codes at all. It doesnt matter if I add "usescancodes=true" to the [sdl] section or not.
Reply 6 of 22, by wd
Rank DOSBox Author
DOSBox Author
This is quite relevant information as then you definitely need the 102 key.
You could try to add some logging that displays what SDL code is
returned for this key (sdl_mapper.cpp).
Search for the "class CKeyBindGroup : public CBindGroup" in sdl_mapper.cpp,
look into the function "bool CheckEvent" there should be an out-commented
"LOG_MSG". Just uncomment it, recompile it and when running dosbox
watch the console window.
Reply 7 of 22, by japheth
this returns the values:
key type 2 is 3c [5c 56] ;pressing the key
key type 3 is 3c [5c 56] ;releasing the key
looks good and tells me that it is not SDL which causes the problem-
(no difference if I add "usescancodes=true" or not in dosbox.conf)
Reply 9 of 22, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
with keyb it works nicely with CVS versions. 0.63 release doesn't work correctly with keyb.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 10 of 22, by japheth
But here the FreeDos keyb.exe doesn't work. And it is impossible to work, because no key codes arrive at int 15h, ah=4Fh, which usually is called very early in the IRQ 1 handler. In fact, pressing 102-key does not even produce any data at keyboard port 60h (which is the lowest possible level).
Reply 11 of 22, by Dominus
DOSBox Moderator
How does keyb.exe not work? Any error message?
Why nothing happens for you there is a mystery to me.
(anything else you do differently? like a self compiled sdl.dll or something like that?)
Reply 12 of 22, by japheth
well, keyb.exe works of course, but nothing happens when the 102-key is pressed.
No, I don't use a self-compiled sdl.dll . Btw, it has already been proved that sdl is not the problem. Dosbox is somewhere swallowing the key, and yes, possibly I'm doing something differently/wrong, but I don't know what. That's why I'm asking.
Reply 13 of 22, by wd
Rank DOSBox Author
DOSBox Author
Did you change something in the mapper? Try to delete mapper.txt,
and use the aep-build with default settings.
For your own build: In keyboard.cpp, function KEYBOARD_AddKey add
some LOG_MSG that displays the keytype, this is one of the next
functions that is called.
Reply 14 of 22, by japheth
after renaming mapper.txt the 102-key works. Thanks for this hint!
then I installed a fresh copy of dosbox.0.63 (6.12.2004) to see what I stupidly may have changed there but it wasn't installed. And I cannot remember where I get my mapper.txt from. I attached it so someone possibly could tell me what the problem is in there.
    MAPPER.TXT
    2.31 KiB
    117 downloads
    mapper.txt
Reply 15 of 22, by wd
Rank DOSBox Author
DOSBox Author
Well the less-than key is missing from the mapper.txt, which means it
has no effect. To generate a valid mapper.txt, delete the old file (as
you did), start dosbox, press ctrl-F1 and klick on SAVE. This is not
really necessary because if mapper.txt is missing, dosbox'll use the
standard set, but you can compare those files at wish.
Reply 16 of 22, by japheth
yes, it works fine without the mapper.txt file
btw, while analyzing the problem with a simple tool which hooks into int 15h, ah=4fh I noticed that keys "caps lock" and "num lock" are handled a bit strange. Once pressed, dosbox doesn't seem to realize that the key has been released again and continues to generate make codes (which then arrives at int 15h) until any other key is pressed.
Reply 17 of 22, by Qbix
Rank DOSBox Author
DOSBox Author
that is correct
sdl doesn't pass numlock capslock release codes to dosbox.
so we cheat a bit by releasing them (in the bios area) on every key
Reply 18 of 22, by Dominus
DOSBox Moderator
curios, does it work with 0.63 for you? I couldn't get the correct < keys with it (when loading keyb.exe).
