First post, by aphuk
I run my legacy application from within DOS box and it appears to work fine until the application tries to use the serial port (COM1).
I have used this application and serial cable before (from other PCs running a 'real' DOS session ) and it works OK. The application opens the com port and communications start and away I go
What foolish thing am I doing wrong within DOSbox?
