Cpu resource
First post, by hozi
I have two pc's the first is a new one and fast and the sec. is old (pIII 800).
In the first all runs OK.
but in the old one the DosBox use the cpu over 95% - this thing make my pc two slow and i can't even run the DosBox in a proper way.
what i need to change?
Tanx a lot.
HoZi 😎
Reply 1 of 4, by DosFreak
Download a CVS build of DosBox from my signature below and report back.
Use either ykhwon'g or gulikoza's.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 4, by Lofty
1. Download CVS build (these are newer and better optimised).
2. Set core=dynamic in dosbox.conf (warning: this will make a few games not work)
3. Increase frameskp in dosbox.conf or use ctrl F8 (*) if still too slow.
4. Increase cycles in dosbox.conf or use ctrl F12 until cpu is at around 90%
Cycles and frameskip tend to need tweaking for each game for optimum performance.
* - ykhwong's build seems to have a bug where ctrl F8 doesn't increase frameskip.
A P3-800 is going to struggle with many games after '93-'94 whatever you do.
Reply 3 of 4, by icemann
Didn`t happen to install SP2 recently did you? If so it has NOTHING to do with dosbox.
Go into task manager and end "Explorer.exe" from the processes list, sounds crazy I know but it is the root of your problem and you`ll only ever have to do that once. Every time you start your computer from then on it`ll run fine.
Two stones, two crosses, the rest is just icing. - 7th Guest
