Reply 23 of 31, by pol
Hello,
I have opl3 chip which is working fine in command line (w98, vxd driver), my question is how to disable dosbox sound emulation and let it pass to the system. Aka from dosbox I only need to put old games into windowed mode. Any way?
Disabling the sound emulation in config file doesn't helped. Nor a little. Anyway here's not direct option to not emulate opl3...
Reply 25 of 31, by pol
It's a bit non-pracitcall that it cannot work in transparent mode, but ok.
I'm usually having no problems with that chip 😊 , but this game - mm3 - like only full dos or dosbox. Cannot put it into windowed moder or buy a newer version, ubisoft says I'm out of allowed region.
Reply 29 of 31, by pol
Haha, it's working 😁
..dosbox load dropped from 100% to about 5. This is just great.
But it's having side effect, with remapping mouse is out.. utterly. I don't need it for this game but eventually can be put back?
Just 5% that's simply amazing 😊
