First post, by work9work
Flags work fine but I can't seem to get other parameters to work.
Run dosbox
>mount c c:\
>c:\program.exe -f textfile.txt
doesn't work says can't load textfile.txt
>C:\program.exe -f "textfile.txt"
doesn't work
>c:\program.exe c:\textfile.txt
doesnt work
>c:\program.exe textfile.txt
doesn't work
I've also tried using a bat file doesnt work
program.exe and textfile.txt are both in c:\
What am I missing to pass a file name as a command line parameter to a program?
Reply 1 of 3, by Lofty
Maybe the program is looking in the current directory, rather than its own?
Does this work?...
mount c c:\
c:
program -f textfile.txt
Though, program.exe -f c:\textfile.txt should have worked regardless...
Reply 3 of 3, by Lofty
Yes. 8 characters is an original DOS limit, and dosbox honours it for compatibility reasons. If you look at a directory listing in dosbox with "dir", you'll see the truncated names and you can use those, or just rename the files to 8 chars or less. 😀
