First post, by Tawmis
I swear I looked around in here first - even through search - but it yeilded way too many results! Powered through the ones I thought had the answer...
Anyway - for the video capture - is there a way to do so without capturing the mouse as well? I checked out the config file... and looked in there to see if there was a
CAPTUREMOUSE: FALSE/TRUE
Kind of thing... and didn't see it. If this isn't possible, I would like to recommend it to the WISHLIST. 😀
http://www.neverendingnights.com
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
uhm well not really possible. unless you remove the mouse.
The mouse is emulted and drawn into the emulated screen. The capture stuff saves the emulated screen.
Water flows down the stream
Reply 2 of 2, by `Moe`
Sicne most games draw the mouse themselves (instead of telling the mouse driver to do so), you're probably out of luck - it's not under DOSBox's control. You would have to alter the game binaries to remove the mouse.
