First post, by Roxor
- Newbie
I've got some rather strange speed issues in DOSBox.
Commander Keen 5 runs really slow, even though the CPU cycles are up pretty high at 30000 cycles (I don't dare put them any higher or otherwise It'll be too much for my machine).
Stargunner, which is much more sophisticated (Protected Mode, VGA, GUS sound), runs at full speed, as do the other Commander Keen games.
All sound devices have their mixing rate in dosbox.conf set too 88200 (my soundcard can handle samplerates that high, so I doubt that's causing the problem). The scaler in use is advinterp2x, the core is set to dynamic, and I'm running WinXP x64 Edition.
Any ideas as to why only Keen 5 is affected like this?
