First post, by GiGaBiTe
I followed the tutorial on how to create drive images and mount them in dosbox, and that worked. But No matter what config I try, I cannot get anything to format a disk image.
fdisk from freedos reports that there is a 0 MB hard drive
fdisk in PCDos 7 just crashes
and fdisk in MSD 6.22 crashes with the error "run-time error R6003 - Integer divide by zero." (it used to at least get into the menu, now it instantly dies.)
The status window reports this:
BIOS INT14: port 3 does not exist.
BIOS INT14: port 2 does not exist.
XGA: read from port 0xE2E0, len 1
XGA: read from port 0x92E8, len 2
I'm fairly sure that I have the drive paramaters correct, and it's set to -fs none.
mount x c:\dosbox\drives\images
imgmount c "x:\c.img" -t hdd -size 512, 63, 16, 162 -fs none
It's an 80 MB image created with that BXimage program.
What the heck am I doing wrong?
Reply 1 of 5, by GiGaBiTe
Ok, i managed to fix the crashbug by doing a fresh install of DosBox, but I still cannot fdisk the drive, as DosBox doesn't seem to support "rebooting" and crashes or freezes when MSD6.22 or FreeDos try to restart.
Reply 2 of 5, by Neville
I was told once on this board that for some reason the MS-DOS install doesn't work properly under DOSBox. Try instead to install from QEMU and then use the resulting diskfile with DOSBox.
Reply 3 of 5, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Where precisely was that said? Could you go to details? If it is so , it would be nice to fix it.... This is a thing DOSBOX should manage...
I cannot remember whether I tried it or not (it is possible I was booting a floppy image and did not bother with the whole MS DOS installation...).
Edit: And I know for sure that I used FDISK in DOSBOX succesfully (as written in DOSBOX Guides)...
Edit (rebooting):
4. After DOS booted I started FDISK and created a primary DOS partition. When FDISK wanted to reboot later, it crashed/froze (depending on DOS version). I ignored it and ended DOSBOX (it is minor nuisance but FDISK already did its work).
5. I again restarted DOSBOX as in the point 3., but instead of FDISK I used: FORMAT C: /S
This formatted the disc and made it bootable.
Mirek
Reply 4 of 5, by Dominus
DOSBox Moderator
Yup, fdisk DOES work, but the 6.22 Setup does not. Me and someone else discussed this some time ago in the developers forum I think (I didn't believe him and tested it and found it not working as well - his original problem was the image size AFAIR)
Edit:
Hmm can't find the original thread I was thinking about, but here is one:
Problem installing to HDD image file.
(and I made small mistake by just stating 6.22 doesn't like he image, I meant of course the 6.22 Setup 😀)
