First post, by ErikGG
- Member
Recently I've been building, yes, another FrontEnd named D.O.G. . I was looking at a lot of posts, and saw that people, beginners or not in DosBox, having troubles with setting up a game as simple as The Elder Scrolls Arena. Thats why I thought, why not build a FrontEnd that allows people to configure a conf file and additional stuff like extenders and sutch, by just selecting the game's name in a list.
The application, at the moment, doesn't support saving a conf file as a link, and the automatic configuration thingy also is currently unavailable. But manipulating the conf file and saving/loading is working. D.O.G. doesn't save its settings as a profile or in another file, it saves it to a conf file and loads it from a conf file, just like DosBox.
D.O.G. is added as a attachment to this post.
Send me your comments.
Thats what I'm trying to do. The application will be compatible with the 0.65 version of DosBox.
I've also set up my pc to compile DosBox, so maybe, If I'm smart enough to figure DosBox out, I'll be making contributions to your wonderfull emulator.
Btw got a question,
If I want to go to a directory with a space in its name, what do i do to go to this directory, because cd "Dir with spaces\dir" doesn't work.
Erik.
