DOSBox Game Launcher (DOSBox Frontend)
Reply 200 of 1970, by MiniMax
Rank Moderator
Moderator
XulChris wrote:
Actually, in Linux config files are supposed to go into the /etc/ directory, but qbix has not yet implemented this.
/me slaps qbix around a bit with a large trout.
DOSBox itself do *not* need the /usr/bin/dosbox.conf file - it is DBGL that expects the config-file to live in the same directory as dosbox.
So go slap rcblanke instead 😀
_________________
Reply 201 of 1970, by XulChris
No, Qbix needs slapping. I supplied him a patch for parsing /etc as well as $HOME, but it was refused because it did not take into consideration
--sysconfdir=DIR read-only single-machine data [PREFIX/etc]
from the configure, and working with the gnu autotools gives me a migrane. If anyone knows how to fix configure.in to put sysconfdir into config.h then I can fix my patch and resubmit it.
Reply 202 of 1970, by MiniMax
Rank Moderator
Moderator
Remind me to look into this configure.in thing in 1-2 months.
_________________
Reply 203 of 1970, by rcblanke
Hi all,
The Linux package has been uploaded to the usual location.
Attached is a Linux 64-bit DBGL package (from Jeff) for testing purposes. For those who care to check it out; please let me know if it worked for you so that maybe I can put it on the DBGL website soon.
Thanks,
Ronald
http://home.quicknet.nl/qn/prive/blankendaalr … 5_64-bit.tar.gz
Reply 204 of 1970, by rcblanke
Hi people,
Red_avatar, Dosfreak, and many more people have asked me to add some custom fields to DBGL. I've been working on this and would appreciate any feedback on the current status.
A total of 10 new custom fields are added, 8 of them strings, one numeric value and one field for percentages. Four of those stringfields are combo boxes, the others are plain fields:
http://home.quicknet.nl/qn/prive/blankendaalr … l/tmp/edit2.png
Two new Link fields have also been added, together with browse buttons for linking local filesystem stuff:
http://home.quicknet.nl/qn/prive/blankendaalr … l/tmp/edit1.png
The settings dialog was changed to allow editing the labels of the new custom fields:
http://home.quicknet.nl/qn/prive/blankendaalr … p/settings2.png
All this results in a main window which could look like something like this:
http://home.quicknet.nl/qn/prive/blankendaalr … l/tmp/main1.png
Tell me what you think, fellows!
Ronald
EDIT: removed the large pics
Reply 205 of 1970, by DosFreak
Damn, that key to quit field is a good idea. (Damnit, thanks for adding yet something else I need to put on my list).
I've always been hesitant to put links to mobygames on my compatibility list for the tons of games I have because I'm worried that eventually the link will change. Shouldn't something like this be better integrated with the site in question instead of just pasting a link? I guess a link that just searches for the game name is the best option in the short term.
Make your games work offline
Reply 206 of 1970, by collector
I tried your .55 Starter Edition download to see how you setup some games in DBGL. I thought that I'd incorporate a couple of the included games and realized a feature that might become needed. An easy way to import and export profiles. I'd copied part of the database.script from the .55SE into my existing database.script after manually editing the values to match my database. This would be tedious with more than a handful.
I know that DBGL has the ability to import Defend profiles, but it would be nice to be able to export and then import DBGL profiles for sharing, distribution, etc. My main purpose would be for archiving games. I already archive all of my floppy games in ZIPs stored on disc and it would be nice to store a profile in the game's archive. This is why I had asked for the ability to have the config file stored in the game's directory.
Perhaps a built in browse function for different paths would be necessary. The import/export would not be so much for the DOSBox settings (although it might be good for a starting place for setting up the game on another machine) but more for the data base for a game. I don't know if this would mean standardizing some fields like category and publisher or if there could be some query from the importer for inexact matches.
It could also prove useful when helping a NOOB to get a game going in DOSBox. I dislike wizards, but it might be good for these people. I could even have profiles for download on my site.
Reply 207 of 1970, by rfc
Sorry, maybe a dump question, but how do you get the screenshots in there? I searched but couldn't find the information ...
Btw, is it possible to provide some kind of filter for the list, which searches for matching names?
Reply 208 of 1970, by _Vyper
rcblanke,
Attached are 32bit and 64bit versions or a Exe4J http://www.ej-technologies.com/products/exe4j/ exe based java launcher for DBGL, along with the source.
First it checks for the jar
in the "DGBL-JAR" environment variable,
then "./dbgl.jar"
then "./dbgl_current.jar"
then "./dbgl100.jar" - "./dbgl001.jar"
then "./dbgl99.jar" - "./dbgl01.jar"
then "./dbgl9.jar" - "./dbgl1.jar"
once dbgl 1.01 is released i can make you a new one (my e4j is full/registered)
    DBGL-E4J.zip
    150.87 KiB
    465 downloads
    DBGL-E4J.rar
    107.7 KiB
    566 downloads
Reply 209 of 1970, by houou
Hmm, I need some help here. I got the Starter Pack after using D-Fend for a while. However whenever I try to load one of the predefined games or make a new profile and load it, the dosbox window just pops up and disappears immediatly. With every single game in the starter pack/every single custom defined game.
Strange thing is, I tried loading my D-Fend profiles into DBGL and they all work flawlessly. I even tried comparing the profiles for a Starter Pack game and games from my D-Fend profile but there doesn't seem to be any difference (though I can't open both at the same time so I probably missed something). Any ideas?
Reply 210 of 1970, by collector
From the download page: "Please note that you MUST let the SFX extract to c:\ in order to let it create a c:\dbgl055se directory." -- in other words, if you don't want it there, you will need to edit the paths.
Reply 211 of 1970, by houou
Ugh. Thanks for telling me, and sorry for not looking.
Reply 212 of 1970, by rcblanke
Hi all,
v0.56 is here:
* Added 10 new custom fields, 8 of them strings, one numeric value and one field for percentages. Four of those stringfields are combo boxes, the others are plain textfields. Two new Link fields have also been added, together with browse buttons for linking local filesystem stuff. Hovering over the links shows a tooltip now. The settings dialog was changed to allow editing of the labels of these new custom fields. (Dosfreak, red_avatar, etc.)
* Added support for PhysFS 7-zip file mounting (Ykhwong or Gulikoza builds only).
* Improved DOSBox version toggling in template- and profile-editing dialogs by adding a new 'Set' button. This associates the template or profile with the given DOSBox version without the need to reload/reset its configuration settings.
* Improved handling of I/O problems when loading configuration files (MiniMax).
* Some code refactoring.
Regards,
Ronald
Reply 213 of 1970, by rcblanke
Ctrl-F5
In the future. Use column sorting for now (up to 10 columns)
Reply 214 of 1970, by DosFreak
Sweet. Probably going to start the process of creating profiles for my games. It will be a slow process since I'll be testing DosBox compatibility as well but it'll be worth it.
Reply 216 of 1970, by rcblanke
bugmenot wrote:
Can you add an option to use profile name instead of a numbre for screenshots dir, like you did for profile names in the past. Thanks.
Maybe, should not be too hard to do. But I will probably take a break for a while (unless some ugly bug pops up), since I haven't been able to do a lot of dosbox testing (read: gaming) lately 🙄
I'll put your request on the future-work list!
@_Vyper: Thanks for the e4j package! Will probably put it my site as an alternative/add-on download. Any compelling reasons to choose e4j over JSmooth?
Let me know if you need help, or notice something that needs work.
Regards,
Ronald
Reply 217 of 1970, by Aisyk
I have a problem with your front-end, it seems a very good front-end, i use normally d-fend on my windows. Now im on a ubuntu feisty fawn and i search a good front-end. That's why your front-end is very interresting for me.
But,
I have a little problem ! I can't launch it !
I have this error :
Exception in thread "main" java.lang.UnsupportedClassVersionError: com/gui/MainWindow (Unsupported major.minor version 49.0) […]
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:539)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:123)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:251)
at java.net.URLClassLoader.access$100(URLClassLoader.java:55)
at java.net.URLClassLoader$1.run(URLClassLoader.java:194)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:187)
at java.lang.ClassLoader.loadClass(ClassLoader.java:289)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:274)
at java.lang.ClassLoader.loadClass(ClassLoader.java:235)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:302)
Thanx for your reply !
Reply 218 of 1970, by MiniMax
Rank Moderator
Moderator
Hmm... Any idea what version of Java you are running on that Ubuntu box?
_________________
Reply 219 of 1970, by Aisyk
I think so... see the picture below...
Is it a good response ?
    44.34 KiB
