First post, by Seanpatrick
I made a loooooooong DOSBox video of Betrayal At Krondor (1:16:20!), but I can't hear any sound...
http://www.takeforum.com/serinea
Reply 3 of 14, by Seanpatrick
OK, this may seem off-topic, but it's about the same video...
I had to reinstall everything on my computer, and I managed to get the Krondor Movie back, but it doesn't show any video on it...it appears as a sound file with no sound.
Reply 7 of 14, by Seanpatrick
Thanks, that did it. 😁 Sorry for not understanding. 😵
Is there any way to add them to Windows Movie Maker and combine them all into one file? (There are 52 files there...in case you couldn't tell by the programs I'm talking about, I have Windows XP)
Reply 8 of 14, by Qbix
Rank DOSBox Author
DOSBox Author
thought virtual dub might handle it.
the reason that there are so many files is that the resolution of each of the files is diffirent from the resolution of the one before that.
Water flows down the stream
Reply 10 of 14, by DosFreak
http://www.virtualdub.org/
He's talking about Virtualdub. A video capturing program.
Most video enthusiasts online don't use Windows Movie Maker because:
1. It's made by Microsoft.
2. It's not Open Source (Hard to fix bugs).
3. It's too easy to use.
4. It requires Windows.
5. It's made by Microsoft.
I'll see if I can make myself use Windows Movie Maker tonight but since I'm using 2003 at home it would probably require some hacking to get it to work.....and I currently don't have a VM at home of XP......and my work machine is running 2003 as well. Whereas Virtualdub runs on every Windows OS (well almost).
Make your games work offline
Reply 11 of 14, by Seanpatrick
I downloaded it and got it working, but I don't know how to put the files together...I'm a complete idiot when it comes to new programs. 😒
Reply 12 of 14, by MiniMax
Rank Moderator
Moderator
And despite all your bickering about MMM, you are here trying to get games run in an application that emulates an Microsoft operating system.
MMM works fine for me.
_________________
Reply 13 of 14, by Seanpatrick
OK, I figured out what the program is supposed to do...it changes files into .AVIs...but DOSBox already saves them as .AVIs and that's the kind of file MMM won't combine.
Reply 14 of 14, by wd
Rank DOSBox Author
DOSBox Author
I don't know Movie Maker, but i'm sure it has a function to create a project
and import existing avis there, scale them to fit the project's resolution
and render them into a movie (avi or whatever you like/it is capable of).
If it can't do that, get some serious video editing software. Not sure if
virtual dub can attach videos with different resolutions, but at least it
should be possible to rescale them and then append all avis with it.
