First post, by Spuz
Greets. As the title suggests, I can't get my DOSBox to run more than 50% CPU (as shown in my task manager). I have edited the config file for DOSBox and increased the CPU Priority, but it always gets limited to 50% CPU.
I'm running Windows XP Home Edition. Does anyone know how to allow DOSBox to run more than 50% CPU?
Reply 1 of 7, by wd
Rank DOSBox Author
DOSBox Author
I guess you have hyperthreading or something similar enabled?
It's no problem then, as dosbox uses only one of those HT-cpus,
but this one at 100% but if you divide it by 2 it'll show up as 50%.
Reply 3 of 7, by DosFreak
DosBox is designed to only use one processor. So yeah, your SOL for now and for quite some time...probably forever. DosBox doesn't really have a need for multiple processors.
Make your games work offline
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
Well you can safely re-enable hyperthreading, this is just an oddity in how
the XP task manager displays the processor exhaustion, they do not
take into account the load-balancing "technique" of HT processors.
Reply 6 of 7, by DosFreak
No reason to disable hyperthreading. The Windows CPU diagram is just not very intuitive when showing processor usage with more than one processor.
