First post, by monksp
Howdy, folks,
I've been sifting through posts here for a few days, and can't find a solution to my problem, though there was one reference to it.
Whenever I use the 'a' key when using DosBOX, it always outputs a '+'. I found mention of usescancodes=false, but I've had that line in the sdi section of my dosbox.config, and I had it as ``set usescancodes=false'' in the autoexec section, but neither solves the problem, and I'm at a loss.
I'm using DosBOX 0.65 on a PPC Mac OS X.3
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
If you send an email to the addres mentioned on our homepage (crew part)
I'll send you an updated version which should work fine.
Water flows down the stream
