First post, by Rick
I have Windows XP (SP2). Drive D is dvd.
I installed Dosbox 0.65. In the configuration file, I added the lines:
mount c c:\games
mount d D:\ -t cdrom -usecd 0 -ioctl
c:
Sometimes when I open the Dosbox, error message appears:
{no disk} no disk was found in drive. Insert disk in drive D.
Then, whether I choose any of the options - abort, retry or continue - the message appears again, then the window of Dosbox opens, and it runs smoothly. What is wrong? On my old comouter, which drive D was CD drive, there was no such problem.
Reply 1 of 12, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
well, if there is no disk in in D:\ then this error might creep up. OR does this happen also when you have a dsik in D:\?
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 12, by Rick
It happens when there is no disk in drive D:.
But that's not the point: the point is that the program is not supposed at all to check whether there is disk in drive D or not, and not to give this error message. It never did on my old computer.
Or maybe is it because drive D is of dvd, not cd drive?
Reply 3 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
why shouldn't the program check the disk ?
afterall you are ordering it to do so with the mount command ?
Water flows down the stream
Reply 4 of 12, by Dominus
DOSBox Moderator
Well, if you don't want Dosbox to check the drive, then don't mount it. I don't mount my CD-Rom drive unless I need it.
You could handle this with a small batch file in your c:\games.
Call it dvd.bat (cd.bat is NOT a good idea 😀) with just
in it.
So when you need the DVD, just call that batch. For games that need it from the start, just remeber to pop the CD-Rom in before starting the batch.
Reply 5 of 12, by Rick
Yes, that's what I did - I deleted that line of mounting drive D from the config file. 😀
But still, of curiosity, I would like to know what exactly is the source of the problem here - whether it has to do with dvd drive or whatever, because that never happened on my old computer - whether there was disk in drive D or not.
Reply 8 of 12, by MiniMax
Rank Moderator
Moderator
And which OS did you have on the old computer?
_________________
Reply 9 of 12, by DosFreak
Rick wrote:
Disc, disk, what's the difference? 😉 the contents of the error message is what important, not the spelling.
http://docs.info.apple.com/article.html?artnum=302152
Make your games work offline
Reply 11 of 12, by MiniMax
Rank Moderator
Moderator
How do your start DOSBox? With a front-end application, a short-cut, drag-and-drop, or from the CMD.EXE prompt?
_________________
