First post, by SteveEberly
Currently DosBox outputs screenshots at 320x200. Is there a a command switch, frontend, or CVS that allows the native resolution of output screenshots to be changed? Specifically to 320x240, 640x480, or something closer to square pixels? Thanks!
Reply 1 of 2, by wd
Rank DOSBox Author
DOSBox Author
Screenshots are meant to be replicates of the game screen, if the game
uses 320x200 dosbox will save that. All post-processing/scaling is better
done in an image processing application.
If you want to save "what you see" try some screen capturing program,
under winxp easiest is the printscreen (or alt/ctrl prtscreen, never know
what does what).
Reply 2 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
use a dedicated program for it.
DOSBox it's screenshots are what the games want to put on your monitor.
Water flows down the stream
