question/s for ykhwong relating to his builds.
First post, by franpa
Dynamic_nodhfpu
what is this? its a setting in "Daum cafe"'s builds. (how does it differ from Dynamic?)
ps. is that how you spell the authors name?
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 1 of 20, by ykhwong
2006-10-12 17:18  c2woody
* src/cpu/core_dyn_x86.cpp, src/cpu/cpu.cpp,
src/cpu/core_dyn_x86/Makefile.am, src/cpu/core_dyn_x86/decoder.h,
visualc_net/dosbox.vcproj: utilize host fpu directly (dynamic
core)
The core means "Dynamic with no host fpu". On the other hand, "dynamic" directly utilizes fpu on cpu.
It is already in cvs codes. (wd added it)
Reply 2 of 20, by franpa
but whats the point? wouldnt it just make it slower?.... like if it doesnt use the fpu wont it just make it work harder?
my website
Reply 5 of 20, by franpa
ok, so...
a) makes it not utilize the FPU situated in your pc
b) has mostly negative side effects (mostly only good for debugging etc.)
c) shouldn't be used under normal circumstances....
correct?
my website
Reply 13 of 20, by franpa
ok then, since there is a choice between the 2 which is best for compatibility since both of them are visible in the current build? full (force)?
my website
Reply 14 of 20, by wd
Rank DOSBox Author
DOSBox Author
I am not responsible for what options are visible in what builds.
Clean cvs builds should be left at the default unless there's a
reason to change it (stability problems (unlikely) -> use the normal
core, game too slow and non-pmode (rare) -> set to the dynamic
core if on an x86 host).
Reply 15 of 20, by franpa
(yes i deleted my last post here)
yes i just updated and yea the normal (simple) and normal (force) options are present in it..... wtf is the secrecy behind the differences between the 2 you still have failed to explain the differences.
my website
Reply 16 of 20, by Targaff
I have to say that while I don't particularly care about the matter at hand, franpa does have a fair point: "You/they don't need it" is not an appropriate answer. I would hope that the "open" in OS would stretch to being open about what development is for if someone is curious enough to ask.
More to the point, though, making obfuscatory replies like that rather than being up front with people is far ruder and far more infuriating.
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
Reply 18 of 20, by franpa
it doesnt matter if it stays in the final release or not... im just after knowing the difference between them.
my website
Reply 19 of 20, by Qbix
Rank DOSBox Author
DOSBox Author
i'm sure this question has been answered quite a few times on this forum.
the difference is how they are coded.
core normal is a case tree and and core that uses function pointers and splits up the operations in a load/operation/save part.
Water flows down the stream
