First post, by allenpan
Readme.txt -
CTRL-ALT-F8 Start/Stop the recording of raw MIDI commands.
i attempt to record to midi file, but i dont see it in any directory or anythwew?
Reply 1 of 3, by MiniMax
Rank Moderator
Moderator
Check the DOSBox configuration file. It defines a capture directory. The directory must exist before you start DOSBox.
_________________
Reply 2 of 3, by allenpan
is already defined, but only picture and video goes in there...midi is no where to be seen
Reply 3 of 3, by Kippesoep
MIDI also goes in there. Are you sure you've pressed Ctrl-Alt-F8 to record the MIDI? BTW, this only works for games using General MIDI or Roland etc. It doesn't do anything for games playing music through AdLib/Sound Blaster etc.
My site: Ramblings on mostly tech stuff.
