First post, by eNTi
when i try to fire up ascendancy (or the setsound.exe - auto detect hardware), dosbox segfaults:
(gdb) bt
#0 0x00000000004782db in ?? ()
#1 0x0000000000479108 in ?? ()
#2 0x00000000004704bc in ?? ()
#3 0x0000000000420cec in ?? ()
#4 0x0000000000406fc8 in ?? ()
#5 0x0000000000406f6a in ?? ()
#6 0x000000000040848d in ?? ()
#7 0x00000000004f1f09 in ?? ()
#8 0x00000000004ef11a in ?? ()
#9 0x00000000004ebe9c in ?? ()
#10 0x00000000004ed31c in ?? ()
#11 0x00000000004ed16f in ?? ()
#12 0x0000000000498d12 in ?? ()
#13 0x00002b0cacb0f394 in __libc_start_main () from /lib/libc.so.6
#14 0x0000000000406ea9 in ?? ()
#15 0x00007fffff0dec28 in ?? ()
#16 0x0000000000000000 in ?? ()
the backtrace doesn't look too helpful, i've included it non the less.
i can run other games. i played eye of the beholder yesterday, with sound and everything.
a friend of mine played ascendancy with dosbox on windows and said, it worked quite well (with sound and all). maybe i'll try that to, so i can rule out a hardware problem.
  • Linux enti 2.6.18-gentoo-r3 #1 SMP Tue Nov 21 11:30:12 CET 2006 x86_64 AMD Athlon(tm) 64 Processor 3500+ AuthenticAMD GNU/Linux
  • X Window System Version 7.2.0
  • gcc (GCC) 4.1.1 (Gentoo 4.1.1-r3)
  • KDE 3.5.5
  • dosbox 0.65
  • nvidia-drivers 1.0.9746 (GeForce 7900GT)
  • alsa-lib 1.0.13 (Audigy 2 ZS)
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
if you can compile dosbox your self you shouldn't strip the binary and compile it with
CXXFLAGS="-ggdb3 -O2"
did you try the cvs of dosbox ?
Water flows down the stream
Reply 5 of 5, by `Moe`
For now, using a 32-bit build is faster (hopefully that will change soon), but making such a build yourself is quite difficult. I think you will have to live with it for now, or use a prebuilt 32-bit linux binary.
