wd wrote:Get a dependency walker then,
A which? :p
(I'll look it up later)
I think exescope can find these, actually. Either way...
wd wrote:
though i doubt this will solve your problem.
Lotsa crap gets messed up, over the years.
And my crap works most of the time, so if I could get DOSBOX to work without reinstalling XP I'd prefer it.
If it crashes that early it's most likely something with sdl. Try upgrading
your graphics card drivers, change the output= in dosbox.conf or try
replacing sdl.dll with an older/newer one.
I tried 62, 63, 65, so I doubt it's old/new code.
I got 63 to work a couple years ago so I'm guessing it's what mf2hd said...
edit quote tag
edit2... welll maybe it is something with the grafix card. that's the only MAJOR difference between a working dosbox for me.
I had a geforce 6200 before going to an x800
