where is dosbox.conf file in Linux ???
First post, by pcuser4
where is dosbox.conf file in Linux ? I can not find it... help me to find it ...
Thanks!
Jack
Reply 5 of 8, by dougdahl
You need to create it from inside dosbox.
Read the README, focusing on the CONFIG section combined with -writeconf.
And the dosbox.conf will only be in the directory that it is created in. If you run dosbox from another directory, it will not find or use it.
If you want to use the same .conf from anywhere than you need to copy your dosbox.conf to /home/USERNAME/.dosboxrc where USERNAME is what you log in as.
(~ is the same as /home/USERNAME under Linux. My apologies if you already knew that)
Reply 6 of 8, by MiniMax
Rank Moderator
Moderator
If you are lost in the Unix file system, try this:
$ find / -name "some-file-name" -ls
_________________
Reply 7 of 8, by tymek
For anyone who reads this, here's a solution that worked for me:
1 - Open dosbox
2 - From within, type the following to generate the rc file:
config -writeconf .dosboxrc
Now you have a generated .dosboxrc file in your home directory which you can then edit to taste.
