Name of VGA font
First post, by Abdull
Hi,
I'm currently searching for the roots of that font that is visible during booting and in the BIOS, for example see http://en.wikipedia.org/wiki/Image:Phoenix_-_ … tup_Utility.jpg or http://en.wikipedia.org/wiki/Image:Pc_boot.jpg.
I noticed that DOSBox uses the same font imho, so I guess the DOSBox team knows about it.
My questions are:
When did this font first appear, who created it?
Does it have a fancy name?
When I boot my computer, where is it loaded from? Is it placed in the video BIOS?
Why does it seem to always be the same font across all mainboards/BIOSes/graphics cards?
Thanks for your help. If I get good replies, I'll start a new Wikipedia article on this font 😁
Reply 1 of 8, by wd
Rank DOSBox Author
DOSBox Author
See http://www.nongnu.org/vgabios/
and especially their file vgafonts.h :
* These fonts come from ftp://ftp.simtel.net/pub/simtelnet/msdos/screen/fntcol16.zip
* The package is (c) by Joseph Gil
* The individual fonts are public domain
Reply 2 of 8, by Abdull
Okay, thank you very much for this information:
I figured out:
vgafonts.h contains three long "file" arrays of files found in the fntcol16.zip archive:
vgafont8[] == VGA-ROM.F08
vgafont14[] == VGA-ROM.F14
vgafont16[] == VGA-ROM.F16
These files are 1-bit bitmaps of characters, .F08 files having 8 bytes per character (8x8 pixel dimension), .F16 files having 16 bytes per character (8x16 pixel dimension). All characters sorted in (extended?) ASCII format.
Well, unfortunately my research still does not answer WHERE the true source of VGA-ROM.x stems from (maybe an old IBM PC?). But I guess, as bitmapped fonts cannot be copyrighted (as the documentation found in fntcol16.zip says), they are just copied from manufacturer to manufacturer nowadays.
Reply 3 of 8, by wd
Rank DOSBox Author
DOSBox Author
Well it's plain ascii, that is the decimal value 10 would be stored as
0x0a (hexadecimal) in the array.
Maybe those files were ripped from some graphics cards, best thing
you could try is contacting the packager of those files.
Reply 4 of 8, by leileilol
I've always wanted a TTF of this font 🙁
long live PCem
FUCK "AI"
Reply 5 of 8, by `Moe`
Use FontForge to create one. I've done so with the C64's font, it's not too much work once you get used to FontForge.
Reply 6 of 8, by madiyaan
Hello all,
I am also looking for a ttf or something that can be installed in Windows XP of this very font. Does anyone have any idea how I can do it? Or better yet, if anyone has already done it, can you link it?
It looks very good for a monospaced programming font. 😀
Regards,
Reply 7 of 8, by MiniMax
Rank Moderator
Moderator
I don't know if it is a TrueType Font or not, but I like Lucida Console for my programming.
_________________
Reply 8 of 8, by Kippesoep
Try http://www.uwe-sieber.de/dosfon_e.html. Note that, when this guy mentions "the DOS-Box", he's not referring to DOSBox, but to the Windows command prompt 😀
