Reply 40 of 47, by egons
this one..
original .amd
this one..
original .amd
The converter only converts .dro files, not .amd. You will need to play the file through DOSBox (version 0.72) and capture it as a .dro file first.
yeah, sure.
try to play and capture song from Amusic and convert grabbed .dro-file
converter says like unsupported 2.0*facepalm*
did you use the right dosbox version? As the dro format has been changed.
Water flows down the stream
nope, i have 0.74 with debugger version(one doesn't grab tunes)
does anyone grab song and convert to MIDI for me, please?
If you can post the DRO v2 file I can convert it to DRO v1 for you, which DRO2MIDI will accept.
i've found 0.74 portable, with no result.
will attach new capture.
thanks!
256bytes.net - demos all-in-one
oh, my friend did the best - he's made tune from the attached file.
thanks!
btw, some .dro-editors/tools like a Hewston *still* have a problem..
