First post, by MartyD82
Hi,
I just installed Need For Speed SE in Dosbox and everything works great - except the videos. With the exception of the intro video, none of the video clips in the game work properly (the sound works, but the image is just a bunch of static throughout the entire duration of the video). I've actually found that real DOS also has this problem with video playback. So my question is this: Is there any sort of patch that I need to install for DOS so that these video clips play correctly?
