First post, by bender_G
Hi all.
I have a floppy image, let's say name.img which contains txt files (to be specific it contains c code). So I startup my dosbox and write down
imgmount a: <path to img>\name.img -t floppy
Everything is done properly except the fact that if i change anything to a file (for example edit a file) i cannot save my changes.
Why is that? Can i overcome it or i should look for a virtual floppy somewhere else?
Reply 1 of 11, by MiniMax
Rank Moderator
Moderator
Sorry - image support in DOSBox is readonly. Meant for stuff like CD's.
_________________
Reply 2 of 11, by wd
Rank DOSBox Author
DOSBox Author
No, floppy and hd images should be fully writeable,
unless i'm missing something here.
Can you copy files TO the floppy image (after img'mounting
with -t floppy as you did) ?
Reply 3 of 11, by bender_G
Well I mounted my hardrive as another drive (b:) and it was possible to copy a file from b: to a: (a: is where i have imgmount my img file). Though, still it is not possible to edit anything on a: even the file I copied.
Reply 4 of 11, by wd
Rank DOSBox Author
DOSBox Author
How do you edit? Maybe try a different editor as well.
Reply 5 of 11, by bender_G
edit.com
It is somekind of dos-boot diskette with edit.com and some turbo c compilers. Any suggestion for editors? My mind is out of ideas
Reply 6 of 11, by wd
Rank DOSBox Author
DOSBox Author
Dunno, maybe look through some shareware archives. Maybe try the
edit/qbasic from dos6.
But i don't see why your edit.com shouldn't work, maybe somebody else
can verify this. What happens if you save? (error message?)
Reply 7 of 11, by bender_G
"edit was unable to access the file 'a:\logfile.txt' ----> this is the exact message.
The funny thing is that I quit edit without saving the changes, but the file no longer exists. It has been deleted and sure not by me..
Reply 8 of 11, by wd
Rank DOSBox Author
DOSBox Author
But edit works fine on regular mounted drives?
Reply 9 of 11, by bender_G
Yes. In fact i installed a virtual floppy and now mount the same img file to the virtual floppy and then mount it to dosbox and works fine.
I tried even to deploy the img file to a diskette and mount the diskette to DosBox and it also worked fine.
Reply 10 of 11, by Jorpho
Is the read-only attribute set on the IMG file itself? (This is quite likely if the IMG file used to be on a CD-ROM.) Or perhaps you are running DOSBox as a user that does not have write-priviledges for the IMG file?
Reply 11 of 11, by bender_G
None of the above. I am the administrator and there is no write protection for the IMG file
