I want to use himem.sys and emm386.exe
First post, by eftekhary_h
Hello
I run my program and give me one error about himem.sys
I set XMS and EMS to true but don't solve my problem
how can I use himem.sys and emm386.exe in DOSBOx ?
or how can I solve this problem ?
thank you
Best Regard
Reply 1 of 22, by wd
Rank DOSBox Author
DOSBox Author
xms=true, ems=true
What program?
Reply 2 of 22, by eftekhary_h
ems and xms features in dosbox.conf set to true
my program is one dos application and run into dos fine but when run in dosbox enviroment give himem.sys error
Reply 4 of 22, by eftekhary_h
Program is reporter application
Reply 5 of 22, by wd
Rank DOSBox Author
DOSBox Author
Aha. Well then boot dos inside dosbox, configure the config.sys accodingly
to load himem.sys and emm386.sys.
Reply 6 of 22, by eftekhary_h
I run DosBox in windows 2003 Please explain future what do I do ?
thank you
Reply 7 of 22, by wd
Rank DOSBox Author
DOSBox Author
See the readme about the imgmount and boot commands.
Reply 8 of 22, by eftekhary_h
thank you
plese hint me I don't have msdos622.img
Reply 9 of 22, by kruwi
Try out freedos. Questions for ms-dos might cause this thread to be locked.
Visit the end of the internet: www.groskreutz.de
Reply 10 of 22, by MiniMax
Rank Moderator
Moderator
eftekhary_h wrote:
thank you
DOSBox can be used in 2 slightly different ways:
  1. Run DOSBox normally, without a real operating system (e.g. a real MS-DOS) and let DOSBox emulate the operating system.
  2. Run DOSBox with a real operating system like MS-DOS or FreeDOS. Then DOSBox only emulates the hardware (disk, screen, keyboard) and not the operating system.
So far, you have used option 1. It could be that your report application uses something in the operating system that DOSBox does not know how to emulate, or emulates incorrectly, and you get the error about HIMEM.
Running DOSBox with a real operating system (option 2) means that you have to give DOSBox access to a copy of the operating system. You can do that if you can create a so called image file of an MS-DOS 6.22 diskette. This is the msdos62.img file. Or you can create an image file of FreeDOS.
Once you have the image file, you can use the imgmount and boot commands to start DOSBox with the real operating system. And then maybe the error will go away.
But we can not create such an image file for you. You have to do that yourself.
_________________
Reply 11 of 22, by MiniMax
Rank Moderator
Moderator
Is that the full name? Which company has made this program?
_________________
Reply 12 of 22, by eftekhary_h
Hello MiniMax
Thank you from your hint ,Reporter Application is writeen by my Company,I want to create msdos622.img and used into dosbox and I wish don't give error for excute program
Best Regard
Reply 13 of 22, by wd
Rank DOSBox Author
DOSBox Author
Sources available? Is it publicly available?
Reply 14 of 22, by eftekhary_h
No ,don't Available Source
Reply 15 of 22, by eftekhary_h
Dear MiniMax
I don't know about your message [And then maybe the error will go away]
please explain future
Reply 16 of 22, by franpa
a IMG of free dos comes with Ahead Nero Burning Software.
AMD Ryzen 3700X | ASUS Crosshair Hero VIII (WiFi) | 16GB DDR4 3600MHz RAM | MSI Geforce 1070Ti 8GB | Windows 10 Pro x64.
my website
Reply 17 of 22, by MiniMax
Rank Moderator
Moderator
If the error is caused by a problem with the way DOSBox emulates MS-DOS, then using a real operating system (with the imgmount and the boot command) might solve the problem.
You said in your first post that my program is one dos application and run into dos fine. So maybe if you run/boot real DOS in DOSBox, then the problem will disappear?
_________________
Reply 18 of 22, by eftekhary_h
I successed to make msdos622.img and copy to c:\images but when run dosbox and mount c to c:\images and type " boot msdos622.img " system give me "non_system disk or disk error" message whenas I put msdos disket in flopy drive then I typed " imgmount d c:\msdos622.img -t floppy"
and "d:" and typed " boot msdos622.img " then system give me "cannot open msdos622.img" message
please hint me for load msdos in dosbox ,
I wrote in config.sys file in disket bootable
"DEVICE=A:\HIMEM.SYS
DEVICE=A:\EMM386.EXE RAM
buffers=30,0
files=127
DOS=UMB
FCBS=4,0
DOS=HIGH"
is it true ?
Reply 19 of 22, by wd
Rank DOSBox Author
DOSBox Author
...means that the disk is not bootable or system files are missing.
How exactly did you create it? Can you verify that the original floppy
is bootable?
