First post, by exofreeze
If I launch dosbox normally, mount my drives, scroll to my game and start it, ctrl-f5 works great.
if however, I launch dosbox from a batch file
ex:
"..\Program Files\DOSBox-0.70\dosbox.exe" ".\play\Nil Soccer\1-0.EXE" -conf ".\conf\dosbox.conf" -noconsole -exit -fullscreen
Everything boots up just fine, but pressing ctrl-f5 does not generate a screenshot. Ctrl-F1 brings up the keymapper, and ctrl-f4 swaps images and such... but ctrl-f5 is a no go.
Any enlightenment to be found on this?
Reply 1 of 4, by DosFreak
screenshots are dumped into a "capture" directory. Probably can't find the capture directory. You can try creating one in the game dir.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 2 of 4, by exofreeze
No, i can find it just fine.
As I said, when I run dosbox normally, I can get the captures just fine. I can even watch them appear in the directory.
When I run it with the above command line though, nothing appears in the directory.
I even did a PC wide png search before I came and posted here.
Anyone else?
Reply 3 of 4, by MiniMax
Rank Moderator
Moderator
So??
Screenshots are dumped into a "capture" directory. Probably DOSBox can't find the capture directory. You can try creating one in the game dir.
_________________
