First post, by Stomp357
I just got me this HOTAS system, and have yet to use the control manager software for it as WinXP does not need it for the controllers to work. WinXP sees it as 2 seperate controls. Can DOSbox use both these controls at once? I set DOSBox to "auto", "2axis", and "4axis", but only the Flightstick Pro works within games (even games that support throttles), and neither the Pro Throttle, nor the Flightstick's throttle work in the games. Only 2 buttons work on the Flightstick within games (even games that support 4 buttons) instead of 4.
I installed the updated .sdl into DOSBox .70. The game I'm trying to get my controllers to work in is Privateer 2 "The Darkning". The Flightstick calibrates in the game, but only works as a 2 button joystick. Neither the Pro Throttle, nor the Flightstick's throttle is detected.
