First post, by brajamine
Okay, I have a problem in dosbox: Whenever im using it, if I use alt-tab,
the program closes. I want to know how you keep that from happening. I
would appreciate it very much.
Reply 1 of 5, by MiniMax
Rank Moderator
Moderator
Which version of DOSBox?
Which operating system?
Graphic drivers?
Does it occur even if you don't run any program in DOSBox?
_________________
