First post, by fjp
I' trying to play an old game (Dragon Lore from Mindscape) in dosbox 0.71 on Debian Linux. It's a 2 CD game. Playing the first CD goes fine, but I can't seem to get the change to the second CD working.
What I've done so far is:
- mount the first CD under linux (mount /dev/cdrom /cdrom)
- start dosbox
- mount CD in dosbox (mount d /cdrom/ -t cdrom)
- start game
At some point the game asks to insert the second CD. However, I cannot unmount or eject the first CD under Linux because for Linux the CD is still in use. And because the game is still running, I can also not unmount the CD in dosbox to free it.
Any solutions for this?
TIA
Reply 1 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
supermount or so.
Personally I use isos or cue/bin for most games. (imgmount supports multiple images)
Water flows down the stream
Reply 4 of 6, by fjp
I think having it as a separate FAQ question immediately below "My CD-ROM doesn't work" would certainly have helped.
Maybe:
Q: How can I swap CDs while an application is running?
A: If you need to be able to switch CD during a game (or other application), you may not be able to do this using a physical CD-ROM in a CD drive, because the host operating system can lock the CD drive as long as it thinks the CD-ROM is in use.
The solution is to create images (either ISOs or CUE/BIN) of your CD-ROMs and to mount them using the imgmount command. This allows you to specify multiple images for a single virtual drive, for example:
- imgmount d /tmp/CD1.iso /tmp/CD2.iso -t iso
When the application asks you to insert the second CD, use CTRL-F4 to change from CD1 to CD2.
The same method can also be used for floppy images.
Reply 6 of 6, by ADDiCT
If you really change the doc, it might be worth to also add some words on command line length. Can be a problem for games with more than two discs, or long paths to the images.
