Sabre Team won't execute
First post, by greenr18
Ok, I installed the latest version of Dos Box and then put Sabre Team on my computer, executed the proper commands, typed in SABRE.EXE and pressed enter to execute the game and nothing happens, it skips a line down and it does not execute the game, it will not execute the installation file either...
Reply 2 of 29, by greenr18
The .EXE file is 342 kb for the actual game, installation is 16 kb, I haven't tried any other games, but I really want to play this one... ****edit****
I just tested Blackthorne and it did the same thing, sort of almost loaded the .exe but never finished and doesn't go into the game.
Reply 4 of 29, by greenr18
Blackthorne won't load, Sabre Team won't load, but Commander Keen 6 loaded just fine... how do I get Sabre Team and Blackthorne to load though? I really wanna play those games, what happens is I try the .EXE and it will almost execute the game but then it just stops...
Reply 7 of 29, by wd
Rank DOSBox Author
DOSBox Author
Be sure you're using a clean dosbox.conf (or rename the existing one,
dosbox will use defaults then) and type the mount commands.
Try using something like "mount c c:\oldstuff", some games are picky
about the location.
Reply 11 of 29, by greenr18
If you mean commands then this is what I've done:
mount c c:\dosgam~1
c:
C:>cd sabret~1
C:>SABRET~1\sabre.exe
as you can see I tried the .exe and it didn't work. it just went down and had the - that flashes and nothing happened
Reply 15 of 29, by greenr18
thats right
***actually it's dosgam~1 before sabret~1 but i've tried it in just c: as well the sabre team folder that is and it still doesnt work
it isn't just doing this with sabre team it seems to not work with a lot of games...
Reply 19 of 29, by greenr18
Nope, didn't work... 😢
***A year or two ago I don't know what version, but I was visiting my mom and on her computer I downloaded Dosbox and played sabre team fine on it, maybe a different earlier version would work...
****ok scratch that, older version does the same thing, i tried .65 and it does the same thing .71 does.
