First post, by stevew_f
Hi folks. First, I gotta say, I LOVE DOSBox, and have v 0.71 so I can play WingCommander 1.
My business: I got new Joystick - Logitech Extreme 3D Pro - that has lots of buttons. WingCommander uses lots of keyboard commands, and I'd like to map some of the common ones to my joystick's buttons.
I've read the README files that comes with DOSBox, but still can't seem to map the events to my joystick buttons.
So how, for example, do I go about making it so that when I press button #2 on my joystick, Wing Commander thinks I'm pressing the commas key.
I used the keymapper utility, and it updated my mapper.txt file so that one of the lines now reads:
key_comma "stick_0 button 2" "key 44"
(including the double-quotes)
But when I start WC (after mounting a c drive), the joystick button doesn't have the desired effect.
Please describe where the mapper.txt file should be located, and the pertinent line(s) in it, or maybe something else that I'm doing wrong.
And how do I go about testing to see if my mapping has worked (without taking the time/pain to start Wing Commander)?
Thanks, people!
Reply 2 of 4, by stevew_f
Thanks for your help. Actually, I should have said that I've used only the keymapper (ctrl+f1) utility in my attempts to map my joystick buttons to keystroke events. I've used a text editor only to inspect the results in mapper.txt (not for editing the file).
The problem remains, though, that I have not succeeded.
It may be that this joystick does not lend itself well to mapping. For one thing, the keymapper utility interprets joystick button#7 as button#2 (i.e. when i press button#7, keymapper records button#2). There are many duplicates like that for my joystick; it has 12 physical buttons, but keymapper records only 4 distinct buttons. Likewise, it has an 8-position hat, but keymapper records only 4 positions. Again, it's a Logitech "Extreme 3D Pro" joystick
Or maybe I'm doing something else wrong.😖
Here's what I'm doing now to test:
In Windows 98SE, StartButton>Run>command
At the MS-DOS prompt, cd c:\progra~1\DosBox-0.71 followed by dosbox
At the DOSBox prompt, ctrl+f1 then click the picture of the , (comma) key, then the Add button, then move the joystick hat to the left (9-o'clock) position. Then I click Save, followed by Exit (from the keymapper utility).
Back at the DOSBox prompt, I type the word exit to close DOSBox in order to be sure that the updated mapper.txt file gets used.
Back at the MS-DOS prompt, I type again dosbox
Once again at the DOSBox prompt, I type mount e c:\progra~1\wc\wc1[\b] then e: then wc.exe
Once in Wing Commander, I go to the little training simulator and try my key mapping, but it doesn't have any effect. The , (comma) key does have its normal effect (which is "roll left").
So then I quit Wing Commander and quit DOSBox and scratch my head... and appeal to this forum for help!
Thanks for same. 😀
Reply 4 of 4, by stevew_f
Yes!
I changed my Joystick type from 4-axis to auto, and now mapping works. I love it! (I should have known to leave the default well enough alone, eh?)
Also, I turned off Button wrapping, and now all my joystick buttons and axes are available for programming.
This is still within v 0.71
I can now roll my ship in Wing Commander by twisting the joystick, and do other functions that were once available only on the keyboard. In the heat of a dogfight battle, this can be a big difference!
The only thing that doesn't seem to work is the hat, but this I can live with.
Hail to the DOSBox people!!!! Not only can I play my old game, but it's even BETTER than it was back in the day!
DOSBox RULES!
Most of all, THANKS to the DOSBOX Folks!
