First post, by gamix
Mounting d: with the map Games works well. But then I can't change into most of the directories there. A couple work alright and I can run the .exe files for those games (yay BTW 😀) but typing "cd Xxx Yyy" for most other maps just yields an "Unable to change to: Xxx Yyy." message. How do I solve this?
I can't really see any difference between the maps that can be opened and those that can't. No maps with spaces in their names open, but some with perfectly regular one-word names won't either. And yet a few will.
Reply 3 of 7, by ADDiCT
wd: LFN/Spaces In DOS? I doubt that... (;
gamix: your post is incomprehensible. What about some examples (mounts, directory names, etc.), and a more detailed description of your problem?
Reply 6 of 7, by eL_PuSHeR
Rank Moderator
Moderator
Do a dir /x command to see what are the shortnames or enclose long names in quotes, just like WD suggested.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 7 of 7, by gamix
That worked, thanks.
BTW, all I meant was that I could open some maps but not others.
