First post, by Lorenis
i just want to know if it is possible to run dosbox on the second screen on a dual screen system
the second screen is a Standard VGA CRT
thanks in advance
Reply 1 of 7, by MiniMax
Rank Moderator
Moderator
Yes, on my PC running the Frozzbos Extreme Edition OS it works very well 😀
_________________
Reply 3 of 7, by MiniMax
Rank Moderator
Moderator
Some operating system I made up since you didn't specify which OS you wanted to run DOSBox under. So maybe it does not work with WinXP. Or maybe it is a limitation in your graphics driver. As long as you don't tell us any details of your setup all we can do is to guess. There is a reason why I have the link to "How to ask questions the smart way" in my signature. You should read http://www.catb.org/~esr/faqs/smart-questions.html#beprecise
_________________
Reply 5 of 7, by njaydg
AFAIR, good ol' MS-DOS never supported dual screen display, so it's probably way out of the scope of this project... I mean, DOSBox is meant to capture that "warm feeling" of playing games from the golden days of DOS, and unless this new "feature" could be easily applied by comunicating with the OS display driver, it would really be a whole lotta work for a very little (if any) reward.
Reply 7 of 7, by njaydg
Oh... ok! I misunderstood then.
However, I think such a function is available on specific graphic cards and drivers. Might be mistaken though... Isn't it possible through driver selection to assign diferent displays/outputs to 2 monitors?
Anyway, it's probably more troublesome than the final reward itself, but interesting concept, nonetheless! 😎
